Tv Antennas and Reception
If the omni antenna you have has an amplifier or does not have a amplifier , then do the antenna favor , get shotgun and put it out of it's misery. . Omni directional tv antennas Do Not reject multipath. Multipath is signal reflections bouncing off of , in your case -- everything and the multipath bouncing signal are super strong. The digital tv tuner has multipath correction , however in your situation there so much multipath and the signals are so strong that the digital tuner is overwelmend.
