Old 26-Apr-2019, 4:48 AM   #24
kb4
just a different thought.
Since the reception seems to change when antenna position adjusted, and different in different rooms etc it could also be a bad connection or a bad piece of coax in the run etc. or bad splitter. I suggest , like rickbb did but for a different reason that you run one coax directly from a single tv to the antenna. Try to make sure all connections are tight etc. This should be the best you can do with that antenna in that location . Might try moving coax a little and see if signal changes. Next would be different antenna location. Also you might ask friends or neighbors in the area what their reception is like and you can often see what antennas are being utilized in the area just by driving around.
Second, pics are generally helpful and certainly can't hurt. Would like to see pics of trees at about 164 degrees preferably from roof near antenna location and antenna installation.
kb4 is offline   Reply With Quote
