Old 22-Apr-2019, 11:54 PM   #11
BigLou80
Hello, BigLou80; welcome to the forum.
Thank you for the link to your signal report.
Yes, WGGB and WGBY are strong enough to cause overload; you can't use a preamp.
WTIC is moving from real channel 31 to channel 34 during Phase 4 of FCC Repack, 6/22/2019 to 8/2/2019
https://www.rabbitears.info/market.p...&callsign=WTIC
Repack Plan
It is possible that they are running at reduced power because of antenna work; they do have temporary authorization for that:
https://www.rabbitears.info/tvq.php?...tems&facid=147
You could call the WTIC station engineer and ask him.
What is the callsign, WTNH?
TVFool is using a defective database to generate reports. A report from rabbitears.info should have a more accurate list of channels:
I finally had some time to check out rabbitears.info . That site has a much more useful way of presenting the data and will be my go to from now on
BigLou80 is offline   Reply With Quote
