Old 17-Apr-2019, 8:47 PM   #109
Tim
Originally Posted by blackstone View Post
When I installed the CM, originally I planned to combine it with the DB but my cables were too short so it's just hanging on the mast.
Unless there is a good reason not to do it, I'm thinking of putting the second PA 18 preamp up to replace the Winegard while I have it on the ground.
No reason not to do so. Just double check after you install the PA18 and make sure you are still getting all your VHF stations. If so, then install your Antennas Direct UVSJ combiner.
