Old 16-Apr-2019, 5:48 PM   #97
I suggest you try too put the db8 on a 35degree agl it will in prove your receive the same way you put a satilight dish on an agl
No. Do NOT do this, it is very unlikely to help and would more likely cause a reduction of reception due to the signal now coming in below the vertical reception pattern.
The antenna should not be aimed at the sky. If there's any tilting to be done on a panel antenna, it would have to be done by adjusting the angle of the mast itself.
As a general starting point, unless you are staring point blank into a cliff or bluff, just put it on a vertical mast so it's aimed in a plane parallel to the earth. There may be times when an upward tilt might be useful, but they are best dealt with on an individual basis after actual consideration of the pros and cons.
