Old 16-Apr-2019, 3:35 PM   #92
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Originally Posted by blackstone View Post
Thanks for that info, Bob.
Antenna Direct mentioned that a while back, too.
I'd hate to change them around because I have the DB 8E zoned in and not sure how long it would take to get it back.
Since it seems that I'm getting good signal now, is it important?
Would that have anything to do with my current situation?
AD Tech is correct, it's not a steadfast rule, merely a strong suggestion to put the UHF antenna above the VHF antenna. So, for now, you can just try the antenna position the way it is and if you like what you have, keep it that way.
I do have a suggestion on keeping the same aim on your DB8e. You can take a 3 or 4 or better yet a 5-foot foot level and scribe a line with a Sharpie on your mast. Make a corresponding alignment mark on your clamp.
Loosen the clamps, slide the antenna down and line up your marks again. That should keep the aim exactly as how you had it. As you've already figured out you will have to remove the other antenna to do this.
Just an idea.
