Old 16-Apr-2019, 12:26 AM   #84
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Originally Posted by blackstone View Post
Yes.
Sort of.
The UHF is mounted on a piece of conduit attached to and old wooden pole that, previously, had a dusk to dawn light.
The center of the antenna is approx. 12-13' above ground.
The VHF is on a separate mast attached to the same wooden pole and Approx. 18' above ground
Just for your information, the UHF should always be above the VHF. I could go into it but it has to do with signals and signal strength and how the signal comes in etc... But as a general rule put the UHF above the VHF.
Unless for some reason there is a tree branch right in front of the upper part of the antenna as UHF as more sensitive to trees and leaves Etc....
