Old 15-Apr-2019, 8:49 PM   #14
JoeAZ
"Not sure I understand the need to move the antenna approx 45 degrees to receive a good signal on PBS?? "
Hi Johnsonbrits,
I have found that when I have UHF antennas mounted horizontal/
perpendicular to the ground, (+) the KAET signals are pretty marginal.
When I rotate the UHF antennas like an "X," the signals most always
improve. I believe it has to do with polarization but supposedly, most
all tv stations have the same polarization. I do not know if the low VHF
Show Low translator would follow suit but thought it might be worth
a try......... Good Luck!
