Old 15-Apr-2019, 5:57 PM   #78
Tim
Originally Posted by blackstone View Post
One last question, please?
(Until the next last question)
Rabbit73's post just made me wonder something.
I have an Antennas Direct Combiner. Also located my second PA 18 preamp.
Would the Antennas Direct combiner work and not need the UVSJ?
I would put the Pa 18 pre amp on my VHF and eliminate the Winegard.
In an earlier post you stated,
"With only the channel master, I get no UHF stations.
9 9 WTOV
13 13 WQED
19 11 WPCW"
Looks like you were picking up your high VHF stations with no problem using the LNA100 amp. If it's working don't change it.
Don't confuse UVSJ and combiner. They perform completely different functions. The UVSJ will hopefully isolate your two antennas from each other and eliminate the signal degradation you are experiencing. Using a combiner to combine two antennas usually does not work well.
