Rabbit73, Great comments, Thanks!
I ran a test this morning using the Hauppauge signal monitor and scanning real channel 3 with the Winegard HD8200U. I found there was NOT a measurable signal to lock onto for channel 3, same test with real channel 7 (FOX) worked fine.
I then took the channel 3 folded dipole (88") and a portable television out on the road and found that even below the transmitter at Porter Mountain there is not a signal on channel 3 (K03FB-PBS). Again real channel 7 transmitting from the same location was fine.
The last time I was in Show Low a month ago I'm certain the transmitter was operational. I'll contact the KAET station engineer tomorrow per your suggestion.
Regards,
Peter J.
Phoenix, AZ
