Old 14-Apr-2019, 3:14 AM   #10
Originally Posted by Johnsonbrits View Post
In both cases, real channel 7 comes in with good quality but PBS on real channel 3 is not picked up during a scan. After tweaking antenna direction for real channel 7, I note through my main TV and PC that the Hauppauge signal monitor shows a SNR in the upper 20's to low 30's but again real channel 3 cannot be found during the scan.
The above results indicate to me that my HD8200U antenna is likely working just fine. The balun, pre-amp and cabin coax cabling are not causing problems. Antenna direction is fine since I was able to tweak against real channel 7 which is also located on Porter Mountain…… Other Thoughts Welcome!!
Thanks again,
Peter J.
Phoenix, Arizona
rabbitears.info shows K03FB on the air:
https://rabbitears.info//market.php?...callsign=K03FB
Either it isn't on the air or you have a high noise level on CH3.
I suggest you call the KAET station engineer at ASU.
Ian MacSpadden
Dir. Broadcast Engineering and Operations
Arizona State University
555 N. Central Avenue Suite 302
Phoenix, AZ 85004
US Phone:+1 (602) 496-1774
Email:Ian.MacSpadden@asu.edu
