Old 13-Apr-2019, 4:06 PM   #30
Nascarken
Banned
You are correct in your assessment that there is a cancellation effect
going on. You need to keep the two antennas separate all the way
to each tv. You can accomplish that by either using an A/B switch
or a separate tuner at each tv. You then need to readjust each antenna
because that cancellation could have caused mis-aiming.
We'll if IT'S A hi gain ANTENNA like the seller's LAB antennas Direct 91at
Is a hi gain ANTENNA manufactures say that DISTRIBUTION AMP
Can all so can cause the same problem they fight one other.
