Old 8-Feb-2011, 11:56 PM   #7
John Candle
Tv Antennas and Reception
Using a rotor with more then one Tv connected brings on unhappiness because where the antenna is pointed thats the programing that everyone will watch. In your reception situation you can install separate antenna systems to point other antennas at other Tv stations and use remote control A/B antenna switches at the Tv locations. If one Tv is connected do not use a splitter , if two tv"s are connected use a two way splitter , if three tv's are connected use a three way splitter. I expect the antenna and amplifier will supply signal to 3 tv's. . In any event , ----> It Time To Put Some Aluminum and Plastic In The Air !!
