Old 13-Apr-2019, 1:05 PM   #29
JoeAZ
Originally Posted by blackstone View Post
Thanks for the response, Tim.
Each antenna is on the same mast with separate lines coming into the house with separate pre-amps.
They are separate until they combine at a combiner to go into my distribution amp
Hope this is what you are asking
You are correct in your assessment that there is a cancellation effect
going on. You need to keep the two antennas separate all the way
to each tv. You can accomplish that by either using an A/B switch
or a separate tuner at each tv. You then need to readjust each antenna
because that cancellation could have caused mis-aiming.
