Hold off on that; it's a last resort. Keep it simple at first; you might want to feed a TV tuner on one TV from the antenna.
Interesting note that might be easiest for me. I have more Ethernet run in the house then coax. My last setup used the HD home run for the movie room computer and the Samsung has DLNA so it can access it, plus tv on the phone. Only concern I've got is heat and moisture with an outdoor install.
