Old 12-Apr-2019, 8:29 PM   #1
98mystique2
Pre-Amp/ Receiver suggestions
Finally made the jump to cut cable, trying to find out what type of preamp setup (or other ideas) to run.
20' and 30' AGL reports
http://www.tvfool.com/?option=com_wr...90385ab1cf819f
http://www.tvfool.com/?option=com_wr...90386ee95febf8
I'd previously had an HD home run for cable which I liked.
Looking to get some of the Chicago channels. Preferably WGN. I know with a medium antenna and standing on the roof with the antenna plugged directly into the tv I was able to get it so there is hope. In an effort to improve chances I bought a DB8e which should be in next week.
So questions
Will I be ok to run a high gain preamp with that or will I over power it with the "localer" Rockford channels? Hoping to install on the side of my house facing Chicago so the house can block Rockford and Madison channels.
Do I need an LTE filter ( I see some of the CM amps have them integrated) if I can see a cell tower less than 1/4 mile away?
Does it make more sense to just run a hd home run on the roof and run Ethernet into the house rather then coax? Where do I put a power inserter then too.
Can power inserters be 50 feet downstream?
98mystique2 is offline   Reply With Quote
