Rabbit73, Thanks for your response. See my initial comments below,
"Did you actually try to receive 3 and 7 with the balun attached to the VHF wires?"
Nope, but I'll be up at the cabin next weekend and will test.
"If you did, and 7 was better than 3, you can try a channel 3 folded dipole as an antenna for 3"
Good idea, I'll go looking for some 300 ohm twin-lead, make up an 88" folded dipole and test.
"Which CM preamp are you using? "
Not sure, I'll check while up at the cabin next weekend and report back.
Thanks again,
Peter J.
Phoenix, Arizona
