Old 7-Apr-2019, 9:26 PM   #6
Originally Posted by kb4 View Post
Exactly need Rabbit73 . Have actually three different antennas I had two directional both pointed at WYJJ and one non directional and tried one with and without amplification just for heck of it. I will look at rabbit ears site etc.
I'm not sure I can be much help.
WYJJ was transmitting on real channel 27 with 10 kW ERP and a directional antenna. They were only sending 9 Watts in your direction.
http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d6
According to the FCC files they are now transmitting 15 kW ERP with a non-directional antenna on real channel 34, so the signal should be stronger than before.
https://rabbitears.info//market.php?...&callsign=WYJJ
https://www.rabbitears.info/tvq.php?...s&facid=188036
https://transition.fcc.gov/fcc-bin/tvq?facid=188036
https://licensing.fcc.gov/cgi-bin/ws...ion_id=2018779
Click on View LMS Authorization to see license.
If you still have a problem, call the station engineer.
If you send me your address and the coordinates of your antenna in a PM, I can try to make a more accurate analysis.
