Old 5-Apr-2019, 2:55 PM   #4
rickbb
Based on your plot I'd try a 4 bay with no reflector and no amp.
Most of your towers are SSE and a few almost 180 degrees from them. With no reflector and aiming at the towers to your south, (assuming no trees, buildings or other obstructions blocking the path), you should get excellent reception from both directions.
I do not think you will need a pre-amp, only if you have long cable runs and split to multiple TV's then you "might" need a low power distribution amp.
Your signals are quite good and the NM is nice and high, any amp could, (and most likely would), over power the signal and the TV would drop it due to the TV receiver just not being built to handle really strong signals.
