Hello GypsyCowgirl and welcome!
Check out the websites of Winegard for its 8200U; RCA 3038 or 3037; and Channel Master for its Advantage 60 or 100, among others. These antennas have longer range, well above 45 miles where your towers are located that have the stations you're desiring. You may not need an amplifier with these types of antennas. Then again you might. And yes, I believe DirectTV uses an amplifier in their receivers, just like cable boxes do. Good luck. I'm sure others will chime in with excellent advise.
