Old 8-Feb-2011, 8:35 PM   #21
m1kzuua8
I came across this FM trap from a local RadioShack store:
http://www.radioshack.com/product/in...uctId=10939219
I put it in, and connected the output to the CM-7000.
Nothing showed up for KGO. 0% signal. Don't know if this RadioShack filter is a poor choice. It doesn't help at all.
I'm going to try to move the antenna a bit further to the NW and see if that helps.
I wonder if I should try the Winegard FM trap if it would do a better job than the RadioShack one. If the poor result of the RadioShack FM trap is a good reference, then perhaps I should opt for a more directional outdoor antenna instead? Would HBU33 get KGO, or I'd still need an FM trap w/ it?
Thx.
m1kzuua8 is offline   Reply With Quote
