					Originally Posted by  ADTech
				The translators to your southwest are duplicates of those over by Cody.
A simple UHF-only antenna aimed at Cody should be all you need.  Shouldn't need an amp, the calculated signal levels are pretty good and, as long as you can mount the antenna so it has a clean view in that direction, should work fine.
Something along the lines of a DB4e and a 30" or 40" J-mount should work fine.
 Hi ADTech,
Many thanks for the reply.  I checked out your webpage and found all the products I need.  Thanks so much for the recommendation.  I do have one followup question.  How can you tell if translators are duplicates?  I'm just curious.  Thanks again!
