Thread: Help Needed
Old 3-Apr-2019, 1:58 AM   #2
The translators to your southwest are duplicates of those over by Cody.
A simple UHF-only antenna aimed at Cody should be all you need. Shouldn't need an amp, the calculated signal levels are pretty good and, as long as you can mount the antenna so it has a clean view in that direction, should work fine.
Something along the lines of a DB4e and a 30" or 40" J-mount should work fine.
