For Nashville:
WTVF is currently simulcasting on UHF-50 and the TVfool plot suggests that signal will be readily received with a suitable deep-fringe UHF antenna. This would make the low-VHF capability of any all-channel antenna unnecessary, significantly reducing the size of the antenna. Additionally, WTVF has applied to build a permanent 1,000 kW UHF-25 facility to replace the current 100 kW UHF-50 translator. That application is still pending at the FCC.
You could choose from either a long-range UHF/high-VHF combo or you could choose separate long-range UHF and high-VHF antennas and combine them with either a UVSJ or a dual-input pre-amplifier.
Hey, you've got options!
