Thanks for the suggestions.
I rescan (almost) daily with no effect.
Antennas Direct support said that one station, WPGH 53, moved from real 43 to 20.
I think they said that it would improve the signal through the hills but decrease it through the trees (or something like that.)
WQED 13 moved from real 13 to 2 and cut their power.
The tech said I might need a low VHF directional antenna.
The other two stations are a mystery.
I was looking at replacing my Clear Stream 5 with something like a Channel Master 3020 or 5020.
I can't determine if the 3020 is a low VHF antenna or not.
Also, looking for the reception angle for the 3020.
Supposedly the 5020 is this:
Reception angles:
VHF L (channels 2-6, and FM) 63 degrees
VHF H (channels 7-13) 34 degrees
UHF 39 degrees
