29-Mar-2019, 4:14 PM
#7
Banned
Originally Posted by blackstone
Rather than start a new thread, I thought I'd resurrect this one because it is still related.
Thanks, in advance, for your suggestions.
After replacing the balun, I still wasn't able to get much reception.
I figured out that my Channel Master amp went bad.
Upon replacement, I got lots of stations again.
For a short while, that is.
I have lost all but one of my VHF stations and can't get them back.
The stations I have lost are:
WPCW 19 which was one of my strongest stations. I was able to get that, almost, with the antenna on the ground. Now, it is very weak and pixelated.
WTOV 9. This one was a long ways off but came in real well. Nothing now.
WQED 13. This wasn't a terribly strong station but it usually came in.
(I have, also, lost WPGH 53 (virtual) and this is the only UHF station I can't get.)
It is my understanding that WQED has moved to low on the VHF band and reduced power.
I was told that WPGH has also moved down to real channel 20.
Right now, the Clear Stream gets WWCO 8 because I pointed it there to get a Fox channel and it's strong.
I have tried from 180 to 245 degrees trying to pick up some of the lost stations but nothing.
I have about one week to decide to return the Clear Stream to Antennas Direct and go back to a directional antenna.
Any thoughts are appreciated.
For what you payed yes you should .
