Solid Signal's write-up appears to be their in-house doing. I can see multiple errors.
Yes, multiple antennas of the same type may be connected following certain rules and with due consideration of the capabilities of the antenna as well as the desired result.
VHF reception via a simple dipole is always going to be a compromise and includes several factors outside the control of the device. The incorporation of a single dipole is a compromise driven by the need to have a very compact antenna that fits in a box smaller than a briefcase so that big-box retail stores will actually put it on their shelves. The alternative is a much larger antenna such as our C5 or conventional stick antennas. Outside of the home centers, you won't find either of those types of products available in-store at any of the national retailers, you'd have to special order them.
