Old 24-Mar-2019, 8:36 AM   #15
kb4
the televes antenna has an amp built in to the balun portion of the antenna that is supposed to automatically adjust the amount of signal and has a filter for LTE transmissions . It can be used with or without the power inserter portion which has two outputs for the TV. In this case the only channel that require the amp to be powered was the Fox channel even with about 130 feet of coax.
I checked with in laws this evening and the reception has been steady. They also rescanned and received two Memphis Channels 30 and 24 virtual for several hours this am from tropo those channels are about 90 miles from them.
Thanks
kb4 is offline   Reply With Quote
