See post #2, I described where I drill them. A hole in each of the corners of the bottom of the housing that are closest to the F-connector. Do not drill in the corners directly under the driven element.
You can do this "in the air", if you choose, but you might get wet!
If you need a photo, let me know and I'll post one up here.
