Well you see that is why I went with the HDB91 instead of the antenna Direct 91st
And the HDB91 has the same performance as the 91st and I like your set up
But know you need too tack it down and see what happen to it Don t for get IT'S
life time w tee.And if you get 2antennas together on top it will look a lot better than just
One antenna with your hi band vhf ANTENNA
