Old 7-Feb-2011, 7:12 PM   #12
kanishk
TheWi-FiGuy
Ground Floor
Originally Posted by John Candle View Post
If the apt. has a second floor , Is a Tv on the second floor?? The best reception will likley be on the second floor. If the reception on the first floor is not so good , put the antenna one close to inside wall that closest to the Tv transmitters. Trees , buildings , and other obstructions reduce the strength of Tv transmissions. Like I say , you best read and understand the information and the information in the links it Applies Directly To You.
Yes, the second floor has a TV, but the apartment is not mine. They have entry on the ground floor and then stairs to directly go to the second floor into the apartment. So, I can't put an antenna on second floor and run a coaxial cable downstairs.
I think my best bet is to go with a non-amplified antenna and see hoe good reception will I get, before I get TWC connection removed.
Also, a TV upstairs and one behind the wall on ground floor on the other side of apartment building may result in signal interference.
kanishk is offline   Reply With Quote
