Old 7-Feb-2011, 6:59 PM   #11
No static at all
No static at all's Avatar
Since you are receiving WETA, I'm convinced there isn't a cabling issue. As John pointed out, the antenna needs to be horizontal (Or even slightly tilted up would be OK as well). If after trying the antenna in different spots, heights & tweaking the aim, a preamp may be needed to help make the desired channels reliable. The TV FOOL shows adequate signal strength, but it isn't always completely accurate.
