Old 1-Mar-2019, 1:23 PM   #3
JoeAZ
You may want to swap out the television having the issues
with one of your other sets. If the problem continues at that
location with a different set, then the issue is probably the
long cable run. If the problem is resolved, then the tuner
in that set is less capable than the others. Additional amplification
will likely cause more problems than it solves. A dedicated
antenna for that tv/location may be your best option.
