Old 7-Feb-2011, 5:42 PM   #10
draken
Only running to a single TV. I'm reusing all of the RG-6 cable that was used with the satellite system. I removed the satellite multiswitch from the cable path, replaced it with barrel connector. Didn't have any issues with the satellite reception, so am I safe to conclude there isn't any issues with the shielding on the cables?
Won't be able to use the under eave mount you showed, I don't have a ladder that goes up that high, and it would be too visible. If the current mount won't work after I level it and double check its bearing, then I'll likely go for something like this that would give me some additional height and could be placed on the back side of the roof (where the current mount is) and still be somewhat unobtrusive. But this is an option after I exhaust all other possibilities using the existing mount.
draken is offline   Reply With Quote
