Old 27-Feb-2019, 12:09 AM   #42
Nascarken
Banned
Well thank you rabbit and the channel master rotors are junk!!
And so I experienced the same problem with the RCA.Rotor
That is why yes $300dollars for a Rotor is crazy to spend.
But you do not have that problem when installing a good quality rotor.
And with the 91xg,you need a Rotor to get IT'S full use.
And the best ANTENNA for the uhf.Well good luck and be safe on the roof and look out for power lines when installing an Tv ANTENNA.
