Old 26-Feb-2019, 4:52 PM   #9
CrackedHead
The antenna you referenced at Solid Signal is another UHF-only design. It does not meet the requirements for reception after October.
The one I linked to is listed as UHF/VHF.
And the one that solidsignal suggested has this in the description:
That's where the UFO shines with it's full VHF/UHF 360° reception.
I edited that post 3 times adding information people requested. You might have seen it when I only had a bit of it. I figured that would be better than 3 different replies. I'm not trying to argue with you, I genuinely want to learn. But it seems like a pretty steep curve
I will fill out your form also, thanks!
CrackedHead is offline   Reply With Quote
