Tv Antennas and Reception
If the apt. has a second floor , Is a Tv on the second floor?? The best reception will likley be on the second floor. If the reception on the first floor is not so good , put the antenna close to inside wall that is closest to the Tv transmitters. Trees , buildings , and other obstructions reduce the strength of Tv transmissions. Like I say , you best read and understand the information and the information in the links it Applies Directly To You.
