Light wave transmission and reception.
Light wave transmission and reception of information , digital or analog , video or audio is the cleanest close perfect way of transmitting and receiving. Unless you know of some way that is better. Draken is correct that it still depends on the source of the audio. Example: The audio starts out bad , every one will say that sounds terrible. The light wave transmission and reception will carry the bad audio in a perfect way , it's bad going in and bad coming out the other end of fiber optic cable. If audio is of high quality going in to the fiber optic cable it will be the same high quality coming out of the fiber optic cable. . Here is a truth. Cable Tv on copper wires uses Very High Levels of digital compression and this degrades video and audio. . Broadcast Digital Television that you receive with a Tv antenna uses Low Levels of digital compression and this better for video and audio.
