Old 9-Feb-2019, 8:11 PM   #19
Originally Posted by corvairbob View Post
thanks just so you know so far my girl still gets tv 8 from that pvc type antenna. i do not get tv 8 at all with my setup. i think that is due to some type of interference between the antennas. i do get 29-1-2-3 so this spring if tv 8 stops showing then i will rescan and see if it improves.
It is possible that there is interference between the antennas; combining antennas aimed in different directions with a splitter in reverse doesn't always work. If you don't have all the channels after combining that you had when the antennas were separate, that method of combining doesn't work for you.
With all those trees in the signal paths, why do you expect good reception? Trees block TV signals.
Scroll down to Trees and UHF
