I have done that, when both the 18 and 20 series PBS channels appear there. Problem is they don't always appear there.
And this does not happen on three other "down stream" tv sets.
A little more background-
We started emailing RMPBS in the fall when we lost the program info on those stations (when they worked). They mentioned something about making changes in late January 2019. And all this started in mid-January 2019. Here's what they said "Over-the-air antennas in your area may have been affected by ongoing updates to our signal, as prompted by the FCC, through the end of January."
Could the government shutdown have affected what they're doing?
And, my antenna points towards the Bayfield CO translators (appx 109 degrees) and one of the Durango translators at appx 342 degrees. The topography here is brutal, ridges everywhere. and those are the only two LOS translators I'm aware of.
