Weird new problem - with PBS only
Sometime late in 2018 our local PBS (Rocky Mtn PBS and channel 36.1 on our TVs) switched over to channel 20.1 (KRMU) and apparently also 18.1.
So the weird thing is, on 1 of our 4 TVs (our primary one in the living room), when I do a scan for digital channels it can't make up it's mind between 18.1 and 20.1 and just sits there and jumps back and forth between the two every second, with almost a strobe light like effect.
After anywhere from a couple minutes to never, it might settle on one of those two channels. But then when you turn off the TV and turn it back on the next day, it starts jumping between the channels again. Has anyone ever seen that kind of thing?
I'm using a Xtreme Signal 8-Bay Bowtie Outdoor HDTV Antenna for over 4 years and have been happy with the results up until now.
Thoughts, suggestions?
Thanks all!
