Old 1-Feb-2019, 5:59 PM   #15
Well you are wrong about that and over load will not happen becuse you are loosing receive during the day time and then at night time the channel 's come back??
And if you add an AMP it will fixs the problem!!!
Adding an amp, especially a high gain amp in strong signal areas usually breaks things.
Reception loss that is related to a particular time of day is almost always due to interference. Adding an amp in those cases only makes things worse since the interference, if within the passband of the amp, is also amplified. Unless the interference happens to be outside the passband of the amp due to a filter in the amp, the amp won't fix the problem.
Simplistic, one-size-fits-all suggestions like to throw an amp at the problem usually are not the appropriate response to reception issues. In very weak signal areas, probably. In metro areas where the signals are strong, nope.
