Hello everyone have you guys looked at the New!! Channel master CM-3011HD
With a channel master 7777AMP at 40ft Hi check it out on your location on the tv Fool report check it out!!!and tell me what you think about it.??
And the way to fixs your problem is go with a channel master 7777AMP!!
And you will receive them DAY and night !!! And you will not get OVER load
If you point the ANTENNA At the BROADCASTING TOWER "S you loos,!!
