Old 7-Feb-2011, 1:36 PM   #3
John Candle
Tv Antennas and Reception
This an example of why I go in to the great detail that I do and also why I become frustrated with the question asker. Here is how to point Tv antennas http://www.kyes.com/antenna/pointing/pointing.html . The Tv antenna needs to be horizontal with the ground. As an example , when you lay down on the ground , you are horizontal with the ground. When you stand up you are vertical with the ground.
