Old 22-Jan-2019, 12:20 PM   #7
corvairbob
Thanks for the interesting antenna photo. Can you zoom in closer?
I think Tower Guy is correct when he calls it a slot antenna, but probably not a skeleton slot antenna. The slots are vertical, but the polarization is horizontal. A skeleton slot antenna has a vertical loop that is the driven element for a vertical stack of 2 yagis with directors. What is unknown, is how directional is the antenna.
https://en.wikipedia.org/wiki/Slot_antenna
try this now and see if it look larger. quality is not as good but you should get the idea.
corvairbob is offline   Reply With Quote
