Old 9-Jan-2019, 12:00 AM   #7
Originally Posted by Kinetic View Post
So it seems that I'm not in an ideal location to receive a strong signal for many of the San Antonio stations.
That is true, you are not in an ideal location to receive them, but I have a few ideas you might want to try.
You need a preamp for the weaker channels from San Antonio, but KNIC is strong enough to cause overload. You could order a custom bandstop filter to attenuate real channel 18, but ChannelPlus makes a notch filter that is less expensive which might work.
Code:
                               Grounding
HD7694 > NF-469 > Juice > coax > Block > coax > Power > TV
                  Preamp                       Inserter
Grounding the coax with a grounding block makes the filter more effective.
