Thread: Alaska Help
Old 6-Jan-2019, 6:44 PM   #5
waldosgone
That sounds promising. The VHF dipole kit should have enough gain for those 4 channels when mounted outside.
The dipole instructions say to use the combiner in the dipole to combine with the UHF antenna, and then have just one downlead. You can try it that way, but if you need more UHF gain for CBS, you must keep the downleads separate for the two antennas to add amplification for UHF only.
I think I’ll go with the separate downleads as I’ll already be up there to run one and two isn’t that much more expense or effort. It allows for future expansion.
I might have been a bit unclear as far as my cell booster plans. The antenna would occupy the same mast but the booster would be inside the cabin and on the opposite wall. 15 feet of separation should be good enough?
Ironically the combiner on Antennas Direct can’t be shipped to Alaska but the antennas can. I’ll have to have it shipped to my parents and pick it up later this month.
waldosgone is offline   Reply With Quote
