Thread: Alaska Help
Old 6-Jan-2019, 4:46 PM   #3
waldosgone
Hello, Waldo; welcome to the forum.
What channels did you get and where was the antenna located for the test?
Where will your new antenna be located?
For the test I placed the Leaf on the east wall (interior)and was able to receive:
KTUU
KYES
KAKM
KYUR
As well as several (12 in total) -series channels.
I then placed the Leaf on the south wall and there was no change in channels received.
Repeated the test with the Leaf on the south window with same results.
The new antenna will be placed approximately 20 feet up on the south side of the cabin. My intent was to use the same mast to put OTA and a cell booster antenna. We are on the lake so the immediate vicinity (at least .25-.50 miles is open water then hills. Between the cabin and Anchorage there are some pretty significant mountains (5-8k feet)
Rabbit - thank you for your help and I look forward to your response. Please let me know if you need any additional info. I was thinking along the lines of the two antennas but was not sure how to actually execute it.
waldosgone is offline   Reply With Quote
