Yes and when the wind blows and over load in mass is not likely
And that is why antennas like the Winegrud 8200U and the HDB,91
Have a front and a back side so on the strongest TOWER'S use the
Back SIDE of the antenna and you will not get OVER load
So if you go up another 10ft with the ANTENNA set-up with a channel master amp
And buy the way!!what kind of ANTENNAs are being used!!
Well can you get 69.1 ion out of newlunden ct
Becuse I can receive it frum zip code 01129
With an ANTENNA Direct 91xg and I get wtnh,channel 8
And on my back side WWLP 22
And if you're antennas are to close together it will do the same thing too??
