Old 7-Feb-2011, 9:38 AM   #2
John Candle
Tv Antennas and Reception
If you have read other question askers posts then you know what is coming. The stations in green at 240 magnetic compass are -->Very Strong<--> DO NOT use any type or kind of antenna amplifier or amplified antenna. http://forum.tvfool.com/showthread.php?t=233 . Read and understand this about Real Digital Tv Channels , Virtual Digital Tv Channels and Analog Tv Channels , http://forum.tvfool.com/showthread.php?t=695 . Here is information of aiming Tv Antennas , http://www.kyes.com/antenna/pointing/pointing.html . Is the apt. wood construction with wood siding or plastic siding or Non metalic siding ?? If not , then what is the the construction?? . . Metal siding , poured concrete walls and brick from ground to roof , reduce and reflect Tv transmissions. Is your apt. ground floor only??
